S300 V3 losing memory
Mark3727
Post by Mark3727 »
Last September I sent in my ecu to hondata and had it upgraded from S300 V1 to V3. I also had the capacitor upgrade offered completed. Everything worked fine until this spring when I upgraded the software to the newest version. Now every time I cycle the key (if longer than 10 minutes) my tune will revert to a stock GSR map. Is there a software update in the works to resolve this issue?
Re: S300 V3 losing memory
Are you only seeing this when you download the calibration, but the car runs the same as long as you don't try to reupload the downloaded file?
Mark3727
Post by Mark3727 »
I have to upload my tune from my laptop to the ECU every time I cycle the key. How I tell it has reverted to the stock gsr map is when I start it my car idles poorly and is extremely lean.
What is the s300 serial number?
Mark3727
Post by Mark3727 »
Serial #64041
Mark3727
Post by Mark3727 »
Any recommendations?
Mark3727
Post by Mark3727 »
Ok I am out of town until next week. I will do as described when I return.
Mark3727
Post by Mark3727 »
Hi Spunkster,
Have you had a chance to review my map that I sent via your instructions?
Thanks,
Mark
