Online ignition on error.
Jbrracer
Post by Jbrracer »
Having issues with another k pro.
When I plug into pc with the ignition off everything seems fine I can see the info screen and everything seems right. See photo one.
As soon as I turn the ignition on it stays online and in the bottom left of reads online and drivers installed and error.
I can’t upload, download or clear the ecu and kmanger seems to go unresponsive and slow.
I’ve completed removed kmanager and reinstalled, the car runs with the problem ecu.
With my other kpro, I have no issues at all everything works as expected.
I’m hoping someone has some insight that doesn’t include me receiving an RMA. Racing season starts next weekend.😢😢😢
Thank you for reading.
Jbrracer
Re: Online ignition on error.
Post by Jbrracer »
Update
If I unplug the data cable from the pc, it goes off line and when I plug it back in it doesn’t go back to online.
Are you using resistor or non-resistor type spark plugs?
Jbrracer
Post by Jbrracer »
Spunkster wrote: Mon May 20, 2024 9:19 am Are you using resistor or non-resistor type spark plugs?
Resistor 5k ngk’s
It looks like this K-Pro was sold as an install kit to HA Motorsports and could be an installation issue. I would recommend that you have them look at it.
Jbrracer
Post by Jbrracer »
Spunkster wrote: Mon May 20, 2024 1:24 pm It looks like this K-Pro was sold as an install kit to HA Motorsports and could be an installation issue. I would recommend that you have them look at it.
That’s correct I was the original purchaser, it’s well outside their warranty period and did work last fall.
Could I swap my working prb ecu for the non working one using the same non working kpro? I thought about trying it but had concerns of damaging a good setup.
You will have to have HA Motorsports take a look at this since they installed it.
Jbrracer
Post by Jbrracer »
Spunkster wrote: Tue May 21, 2024 2:56 pm You will have to have HA Motorsports take a look at this since they installed it.
I'm guessing this is the culprit
was this a ground short thought the ecu or an issue i will have on a new one?
tomsawyer
Post by tomsawyer »
Jbrracer wrote: Sun May 19, 2024 3:19 pm Having issues with another k pro.
When I plug into pc with the ignition off everything seems fine I can see the info screen and everything seems right. See photo one.IMG_8897.jpeg
I can’t upload, download or clear the ecu and kmanger seems to go unresponsive and slow. io games
The problem occurs when the ignition is turned on, which could indicate a communication or compatibility issue between the K-Pro and the vehicle's electrical system.
Jbrracer
Post by Jbrracer »
Hello spunk,
Thanks for all your help with my previous issues. I truly appreciate it.
I wanted to ask a question and get a strait from the source.
I have a k swapped 1990 civic hatch using a 04 rsx m/t harness as you can tell I have a damaged ecu and with the current economy another prb is out of the question right now. I’ve found a pnd-a59, I don’t need the vss or reverse lockout for my use case. I’m currently running a bone stock k20 from a type s and have a built k20 on the engine stand.
My question is will the pnd-a59 work for my situation.
Thanks again, I can’t imagine what you go through answering questions and forum responses every day.
Thanks again
Details on using an auto ECU can be found at: https://hondata.com/tech-alternative-ecu-engine-swap
mrjdc5
Post by mrjdc5 »
hey any updates with this, I have the same exact probiem. I sent my kpro out to hondata, they put it in another rsx and they said it worked perfectly fine. even drove the car with my ecu. when I got the ecu in return I'm having these same issues. key on and it saids error next to driver and goes offline. if I turn key off and unplug usb and reconnect usb it works fine until I put ignition onto key on the fuel primes and instantaneously throws the error code everytime. please let me know if you found an solution to this.
