2004 EP3 Type R K20A2 PRA Turbo Base map Required
Jeffmunro
Post by Jeffmunro »
Hi,
I would really appreciate someone creating a base map for my turbo build.
2004 Honda Civic EP3 Type R K20A2 PRA Ecu
KPRO V3
Grams 1000cc injectors
Skunk2 4 Bar Map sensor
Borgwarner S200 Twin scroll turbo
Sidewinder manifold 3 inch down pipe to 2.75 catback
Turbo smart WG45 external wastegate
Mac 3 port boost solenoid wired to evap purge plug
Tial 50mm BOV
RBC Inlet manifold
70mm throttle body
Any help would be much appreciated :)
Thanks!
Jeffmunro
Re: 2004 EP3 Type R K20A2 PRA Turbo Base map Required
Post by Jeffmunro »
I have stock IACV and I do have innovate lc2 but would not like the ecu to rely on that and use it for datalogging only, the car also has a sytec 340 lph fuel pump and a 7psi wastegate spring
