Page 1 of 2
05/06 RSX with k20a2
Posted: Wed May 08, 2024 8:38 pm
by Kreetoes
Get crank but no start. I NEED HELP YALL
Re: 05/06 RSX with k20a2
Posted: Thu May 09, 2024 9:35 am
Is the immobilizer enabled or disabled in the calibration?
Posted: Mon May 13, 2024 7:25 am
by Kreetoes
Immobilizer is disabled.
For more context, I hade the 05 base harness with the new engine in and still had the same problem. Car started with the base ecu but no the kpro. I was then told to switch to the engine harness for the actual engine. Here I am no with the same problem of getting a crank with no start. I have all the right sensors and modified the harness to what needed to be modified. Could it just be that i have the wrong settings on my kpro?
Posted: Mon May 13, 2024 7:37 am
by Kreetoes
NOTE: I have the conversion harness for the kpro
Posted: Mon May 13, 2024 9:22 am
What is the serial number that is on the K-Pro bard inside the ECU?
Posted: Tue May 14, 2024 12:47 pm
by Kreetoes
Serial Number on ECU is 37820-PND-AO5
Software Version 4.5.9.0
Posted: Tue May 14, 2024 1:19 pm
I need the serial number on the K-Pro board inside the ECU.
Posted: Wed May 15, 2024 5:22 am
by Kreetoes
Posted: Wed May 15, 2024 9:31 am
According to our records this K-Pro was not modified for use with an 05-06 RSX and was not sold with an adapter harness.
Posted: Wed May 15, 2024 10:03 am
by Kreetoes
Should I contact to send it over to get it modified and would I need a new conversion harness?
Posted: Wed May 15, 2024 10:11 am
by Kreetoes
Also is there a copy of the initial form that i sent when ordering the kpro. If this is case, how come I was able to run the K-pro when i had my K20A3 still in the vehicle.
Posted: Wed May 15, 2024 10:17 am
Where did you get the adapter harness?
Post a picture of it.
Posted: Wed May 15, 2024 10:31 am
by Kreetoes
My coworker had one. Figured it would save me money since he had no use for it anymore.
Posted: Wed May 15, 2024 12:07 pm
That will not work properly as the ECU was not modified for use in an 05-06 RSX.
The form you need to use to get the ECU modified and purchase the adapter harness can be found at:
http://hondata.com/downloads/05-06_rsx_ ... e_form.pdf
Posted: Wed May 15, 2024 12:16 pm
by Kreetoes
Okay thank you for your help!
