Page 1 of 2
2013 Civic Si Stage 1
Posted: Sun Apr 14, 2024 2:31 pm
by Josey Wales
Hello all. I recently bought a 2013 Civic Si which was stock except for K-Tuned SRI. I purchased an Acuity Curl Control CAI and a Flashpro. I installed the CAI, then babied it home. My plan is to get a DP with high flow cat, then eventually an intake manifold. My first flash totally transformed the car. My only concerns were the first cold start caused a brief engine rattle, the first log revealed 16 knocks on a 30 mile trip with mixed driving(although it was all mild driving). Also first gear is a little jumpy.
My first datalog looking for knocks.
datalog0000.fpdl
Thanks for looking
Re: 2013 Civic Si Stage 1
Posted: Sun Apr 14, 2024 3:16 pm
by Josey Wales
Here's my Calibration file:
2013CivicSi1.01.fpcal
Posted: Sun Apr 14, 2024 5:43 pm
by CalibratEd
The MAF needed minor adjustments. I reduced timing where knock was present. Create another normal drive log. I want to confirm my changes took effect.
- Ed
Posted: Mon Apr 15, 2024 7:54 am
by Josey Wales
On it. Thanks Ed
Posted: Mon Apr 15, 2024 8:08 am
by CalibratEd
No problem.
-Ed
Posted: Mon Apr 15, 2024 12:38 pm
by Josey Wales
Same drive. Only going the other direction.
CivicLogRev1.fpdl
Posted: Mon Apr 15, 2024 4:40 pm
by CalibratEd
- Ed
Posted: Tue Apr 16, 2024 3:50 pm
by Josey Wales
Thank you, Sir. Here ya go, Ed
CivicLogRev2.fpdl
Posted: Tue Apr 16, 2024 4:15 pm
by CalibratEd
Only a few counts of knock left. Create a similar log.
- Ed
Posted: Thu Apr 18, 2024 12:34 pm
by Josey Wales
I created a new log, but the file was too big. I will make another after it stops raining. I tried to highlight half of it and save, but couldn't figure out to save that portion of it
Posted: Thu Apr 18, 2024 1:20 pm
by Josey Wales
Zero knocks until a did a hard pull to pass a truck. Then 16 knocks in 2 seconds. Oops
Posted: Thu Apr 18, 2024 1:39 pm
by CalibratEd
Josey Wales wrote: Thu Apr 18, 2024 1:20 pm Zero knocks until a did a hard pull to pass a truck. Then 16 knocks in 2 seconds. Oops
Modifications I have made are to make it run safe for normal driving only. Don't drive the car hard.
To shorten the log, right click at the point where you want to cut it and select set new end the save the log.
- Ed
Posted: Fri Apr 19, 2024 6:31 pm
by Josey Wales
Thank you. I'll make a note of that. Meanwhile, I made another run.
CivicLogRev3.fpdl
Posted: Fri Apr 19, 2024 7:33 pm
by CalibratEd
I cleaned up a few counts of knock. Create another normal drive log.
- Ed
Posted: Sat Apr 20, 2024 12:33 pm
by Josey Wales
I did have a momentarily lapse of judgement. Realized it immediately.
Make note; Datalog was done on 87 octane. Let me know if you need another log instead.
CivicLogRev4.fpdl
