i need a good tune for my 1994 honda civic ex coupe fwd im getting a boost controller, new exhaust manifold and turbo gaskets. it has an emusa turbo it’s about a 25mm if not 30. i have a hondata s300 p28 ecu ill list the rest of the parts below.
bottoms end built, stock z6 head, ARP head studs, stage 5 clutch, new poly bushings for suspension, adjustable upper Icas, and billet lowers, trac bar, 4 core radiator with matching aluminum shroud and decent fan,3" piping through out the cold side, pro-charger blow off valve, custom down pipe welded and made by me, wide-band, boost, 4 bar map, 70mm skunk2 alpha throttle, crankcase breather converted to a 10an fitting to run catch can, adjustable cam gear, 1000cc injectors (ksm Motorsport), short shifter, Sparco driver, black s2k passenger, quick release, sound deadening done, Hondata s300 on a p28, e85, tuned by JR at HPO, intake and gaskets have been port matched, same thing with t3 manifold and exhaust housing on turbo.
d16z6 turbo tune
Jump to
- General
- ↳ Hondata News
- ↳ Applications
- ↳ Non-Hondata
- s100/s200/s300
- ↳ s300 / SManager
- ↳ S300 Calibrations
- ↳ SManager Display Templates
- ↳ s100/s200
- ↳ Romeditor 4 Software
- ↳ HondaLogger Software
- ↳ Coil Pack Retrofit
- K-Series
- ↳ K-Pro / KManager
- ↳ K-Pro Calibrations
- ↳ KManager Display Templates
- ↳ K-Series Reflash
- FlashPro
- ↳ FlashPro Manager
- ↳ FlashPro Calibrations
- ↳ Accord 2008+ FlashPro
- ↳ Civic Si 2006-2011 Americas
- ↳ Civic Si 2012-2015 US/Canadian / 2013+ ILX
- ↳ Civic Type R 2006-2010 Japanese FD2
- ↳ Civic Type R 2007-2011 European FN2
- ↳ Civic Type R 2015+
- ↳ Civic 2016+ 1.5 Turbo Americas/Asia
- ↳ CRV 2017+
- ↳ CR-Z 2010-2012 US/Europe/Asia
- ↳ Fit 2007-2008
- ↳ RDX 2007-2012
- ↳ S2000 2006-2009 Americas/Europe/Asia
- ↳ TL 2007-2008
- ↳ TSX 2004-2014
- Traction Control
- ↳ General / Traction Control Manager Software
- ↳ Traction Control with S300
- ↳ Traction Control with KPro
- ↳ Traction Control with FlashPro
- Bluetooth Mobile Apps
- ↳ Hondata Mobile
