Why does my car die??? High boost JRSC'D
Posted: Fri Sep 17, 2004 8:30 pm
by MMIGSR
I got the High Boost JRSC kit. (2001 INTEGRA GSR) It came with the hondata ecu, the s200, and the rc injectors. One we finished installing the kit. We went for a test drive and every time you let go of the gas the car would die. We called Jackson Racing and they said it was a vacuum leak. We checked everywhere for leaks and couldn't find any. So we took the car to an acura dealer and they couldn't find any leak either, so what they did; they manualy adjusted the AIC valve. The car doesn't die anymore but when you let go of the gas the car feels like if it's going to die and the rpms go up and down constantly. I still can't figure out what the problem is. Could it be the Hondata ecu??? Help please!!!
Posted: Mon Sep 20, 2004 9:49 am
Since all cars run slightly differently, you may need to take the car to a Hondata dealer and have them slightly adjust some of the idle settings for you. They should be able to do this for a very reasonable cost.
Posted: Thu Sep 23, 2004 4:41 pm
by MMIGSR
Thank you I will try that. I hope that solves the problem.
Posted: Mon Sep 27, 2004 10:49 am
by 00JRSC-SIR
