S300 sample canbus data
themagicmTX
Post by themagicmTX »
I'm looking for a 2-3 sec dump of raw canbus data from the s300.
Can someone supply that. Also if possible, some values. Ie: rpm was 500 thru 2500, coolant was 80 thru xxx etc.
Thank you
DaX
Re: S300 sample canbus data
Post by DaX »
Hondata is not open source, so I'm not sure you'll get what you're looking for.
themagicmTX
The protocol layout is known. Its just sample data from the ecu. If I find one locally I'll just pull the data myself but I have other ecu's I'm writing support for.
