HELP NEEDED TO MAKE K20A2 WITH HONDATA RE-FLASH RUN PROPERLY
rasle
Post by rasle »
Have put a KA20A2 engine in a rear engined track car. It has been transplanted complete with all engine wiring and a Hondata Re-flash ECU.
The electrics work OK but the engine will not run properly.It has been connected to a Hondata K-Pro ECU for diagnosis which shows an error code of PO341 variable valve timing (VTC)phase-gap.
The vtc solonoid valve has been tested and works off the car.
It doesn`t work when connected to the engines wiring.
There is power at the ECU but no signal appears to be being received by the VTC valve.
I am unable to work out how this signal is innitiated to test it back.
Can anyone help.I am getting confused and frustrated.
Any help will be much appreciated.
Tony.
