Nitrous Installation
Posted: Tue Sep 14, 2004 5:30 am
I will use the power steering input (the sideeffect is that the idle does not get higher when you turn the steering wheel) and the purge control solenoid as an output for the nitrous solenoid. My question is:
I locate the cable corresponding to the PCS right near the ECU. If I cut this cable and connect it to the nitrous solenoid, obviously the PCS will not operate. What is the side effect of this? No purge control valve anymore? What exactly does the PCS?
