1990 CRX Si - D16a6 - PM6 Application?
Shoa Lin Wu Su
Post by Shoa Lin Wu Su »
Sorry if this gets asked a lot, I did a few searches on here and came up with nothing. I am running the engine/ecu in the heading right now, and am wondering if I have any options as far as Hondata goes. Can I run Hondata currently with no changes, is there an ECU that will run my engine properly and is compatible with Hondata, or am I forced to do an engine swap in order to utilize Hondata?
Thank you all in advance for your help and comments.
Dan Grabko
ice-burg-slimm
Post by ice-burg-slimm »
You shouldn't have any prob running a LS ecu because i ran one on my
single cam ZC when i had it,and it was good.
NOTE:you will have to convert to OBD1
