FN2 Type R - Rotrex SC MAP help!
dipsyv
Post by dipsyv »
Hi Hondata,
I am new to the Hondata software so wanted your opinion on the current MAP I have on my FN2 and any advice you can give. The car is expected to go on dyno soon but in the meantime I have been doing some running in miles as I have rebuilt the engine. I have some logs in the attached folder. Currently I do not exceed 3.5k rpm to be safe.
The car has been rebuilt will following mods
- Forged pistons and rods
- Stock FN2 head
- Stock intake manifold
- 1000cc DW injectors
- Stock fuel pump - ( I have a high flow pump but not installed yet, planning to install before dyno)
- Rotrex Supercharger C38-81
- 4 Bar Map sensor
When setting the injectors to 850cc it seems to run smoother than with 1000cc as the input.
Thanks for your support.
