B16A Turbo ID2000 E85 Going Fully Lean After 150 Degree Coolant Temp
Posted: Sat Jan 20, 2024 3:43 pm
Hey Guys,
So I have been fighting this issue with my car for almost a year now & I feel I have exhausted every thing I can at this point to figure out why this is happening. Quick back story, car was tuned on a new turbo in May of 2022 & ran amazing making almost 40 PSI and around 700WHP. Other than the turbo, nothing else was changed and tune from previous turbo was perfect in cold or warm weather. Every winter I would pull my injectors to have them clean & flow tested which once again I did in January of 2023 as peace of mind. Injectors came back perfectly fine & all flowed as they should according to my tuner. Well come May of 2023 when I started the car up for the first time after installing the cleaned injectors, I noticed my cold start AFR's were a little leaner than usual sitting round 12-13 instead of 11-12 which didn't bother me much. However, as soon as my coolant temp hits 150-155 degrees Fahrenheit, its like a flip of switch & my AFR's will immediately go to reading --- on the gauge because its so lean and the idle is audibly different almost like its mis-firing. Even when applying some light throttle, the AFR's will sit very lean until I apply more then 5-10% throttle then it will register on the gauge between the 13-15 mark but even when holding the throttle it will slowly begin to creep back to lean again. I pulled the plugs and they are very white so clearly it is running very lean as shown on the AFR gauge reading ---. I have checked everything from replacing my Walbro 525 pump & new strainer, confirmed fuel pressure is correct at idle (51 PSI) along with pinching the return line which sky rocketed the pressure to 100+ psi, checked inline fuel filter, had injectors cleaned/flow tested again, checked timing & ignition/spark which was perfect at 16 degrees, did a compression test which was around 200 psi across the board & verified all sensors look to be reading as they should. I sent a datalog to my tuner & even he is stumped at this point. I don't know if it will help much but I have attached multiple datalogs of the idle from a dead cold start to fully warm to see if anyone can help me along with the tune I am currently running. The car does have Kelford 176T camshafts, so that is why the idle is higher than normal. Any help is greatly appreciated as I am honestly so burnt out at this point being that the car isn't even drivable because it runs so lean & breaks up really bad even when trying to cruise down the street. Would really like to just enjoy this car again as it has been super solid for years & has never given me problems until now. Thank you.
