Where to start. New with tuning
Apoq
Post by Apoq »
Oh boy where do I start with this tune. 06 si with k&n typhoon intake. Currently using a map based race calibration because maf ones were going way lean at wot. I know race calibrations are outdated but its the only one where I didn't have to make fuel tables from scratch it seems.
Having lots of knock with a ton of k.retard. Found some spots where I can reduce the timing for the vtec ignition tables as well as some in the low ignition tables but I don't know if that would help with k.retard. Its running much healthier than stock or any maf calibrations ive tried but there is still a worrying amount of knock. I'm inexperienced with this so I wanted to know what routes there are to deal with the k.retard. I feel like a lot of areas need to be touched in this tune besides timing though. If any of yall have any reference calibrations for an intake like this that I could take a peak at that would be great too.
racemapdatalog.36 knocks.fpdl
Apoq
Re: Where to start. New with tuning
Post by Apoq »
Edit: after some digging I found an afm calibration by EFICU that seems to butter every biscuit i had here. No knock or nothin thus far. Will be very educational to compare, already noticed how shite the timing and fueling was on the base map.
CalibratEd
Post by CalibratEd »
Apoq wrote: Sun Jan 14, 2024 10:00 pm Edit: after some digging I found an afm calibration by EFICU that seems to butter every biscuit i had here. No knock or nothin thus far. Will be very educational to compare, already noticed how shite the timing and fueling was on the base map.
Glad you found a good basemap to learn from. EFICU is a great tuner. Feel free to post any question you may have.
- Ed
Instagram: calibrated.tuning
