wideband lower range not accurate in datalog
Posted: Fri Jan 05, 2024 9:44 pm
I've had this issue since I started tuning my car where the wideband does match the datalog up until about 12.0:1 and richer afr. After that hondata just reads 11.5-11.8:1 afr even though the gauge is pegged at 10 or between 10-11.0:1
I've tried using D10, B6, Analog input and they all do the same thing. I have AF under the sensors tab set to display the correct range of 10-20
Wideband is grounded at thermostat housing with heavy gauge wire. Everything works and reads fine until it gets into the 10's
