Need help with proper tune 06 Si
Posted: Wed Dec 27, 2023 10:21 am
by JT-06-si
I'd like to be able to drive normal and WOT once in awhile.
I currently have FBO:
K&N SRI v2,
1320 performance headers (...),
Invidia Q300 exhaust.
Currently running on
Hybrid(Vtec4600).fpcal
Datalog:
datalog0000.fpdl
Re: Need help with proper tune 06 Si
Posted: Thu Dec 28, 2023 10:17 am
by JT-06-si
I switched over to this cal and enabled AFM with Use speed/density with Minimum pressure at 70.03 kPa.
Posted: Fri Jan 05, 2024 4:35 pm
by JT-06-si
Here is another datalog that recorded 3 total knocks in KCount2 and KCount3.
Is my tune going to kill my engine?
datalog0005.fpdl
Posted: Fri Jan 05, 2024 10:34 pm
by CalibratEd
I suggest you reduce the timing in the area you see knock. I also suggest you add fuel in the higher RPMS. Its running a bit leaner than I would run.
The lower ends is running fine as its using he MAF sensor and dialed in well.
- Ed
