Turbo TSX basemap
Posted: Tue Dec 26, 2023 8:53 pm
Hello,
This is the current map I've made to run with my 2006 TSX with a G30-770
8.7 psi Tial spring on a jackspania sidewinder manifold, custom DP
1000c DW injectors with an aem340
The car runs pretty well, it still has some low load hesitation, but going WOT from 2k, it picks up great, full boost by 3800.
No signs or sounds of knock, and the spark plug bands have two timing marks on the bend of the strap and look great.
Current issue being the car over boosts to 15psi with only my 8.7psi spring...
The wastegate is plumbed to the Turbo housing, and the intake manifold seemed to make it worse.
The map is locked on 0 degrees Cam timing, and only runs in Open loop to make fuel map tuning easier.
I had a previous ignition table made up with more timing and I wasn't having over boosting issues, I'm assuming that is why, but looking for some opinions.
Cheers
Cheers
