Civic EK engine swap with EP3 ECU
Posted: Thu Dec 14, 2023 9:15 pm
by ponsit
The ECU model is 37820-PRD-013
I'm facing 2 problems.
1. The primary PHO2 is not function. Look like heater is function not properly.
Because after running engine hard enough the O2 sensor functional normally.
I'm not sure the PRD ECU have different pin-out from the link below or not ?
https://www.hondata.com/tech-k20-swap-wiring
2. The multiplexer is disabled, The engine stalled occurred when AC on.
I'm not sure the K-Pro function "Alternate AC Switch Input" will help or not.
If yes, which pin I should wire the AC signal to B-09 or B-11 ?
Thanks,
Ponsit.
Re: Civic EK engine swap with EP3 ECU
Posted: Fri Dec 15, 2023 10:23 am
What oxygen sensor are you using?
VTP is B9.
Posted: Tue Dec 19, 2023 1:32 am
by ponsit
I'm using stock O2 sensor.
Posted: Tue Dec 19, 2023 10:06 am
stock from what though?
Posted: Wed Dec 27, 2023 1:05 am
by ponsit
Spunkster wrote: Tue Dec 19, 2023 10:06 am stock from what though?
Stock from DC5 [Integra Type R]
Posted: Wed Dec 27, 2023 1:06 am
by ponsit
Spunkster wrote: Fri Dec 15, 2023 10:23 am What oxygen sensor are you using?
VTP is B9.
Thank you for clarifying.
Posted: Tue Jan 02, 2024 9:47 am
When you datalog, what errors are you seeing?
Posted: Wed Jan 03, 2024 7:21 am
by ponsit
Spunkster wrote: Tue Jan 02, 2024 9:47 am When you datalog, what errors are you seeing?
Stock calibration, there are 2 error codes
- P0563: VBU Voltage High
- P1162: Air Fuel Ratio (A/F) Sensor (Sensor 1) slow response
Log file >> https://1drv.ms/u/s!AqqwTXO2SH6KgZwAc3cF6uFYBYNyFA
Custom calibration, I have disabled 2 items [P1167 & P0134] inside "Closed Loop" parameters.
- P0563 persisting
- After full throttle, The O2 sensor start responding at cursor 0:01:25.728s
Log file >>> https://1drv.ms/u/s!AqqwTXO2SH6KgZwGvXR ... w?e=OXVq8E
Posted: Wed Jan 03, 2024 10:02 am
You need to try your ECU on a known working vehicle and see if it reads correctly. If it has the same issue, then the ECU is most likely damaged and would have to be replaced.
Posted: Mon Jan 08, 2024 9:19 am
by ponsit
Spunkster wrote: Wed Jan 03, 2024 10:02 am You need to try your ECU on a known working vehicle and see if it reads correctly. If it has the same issue, then the ECU is most likely damaged and would have to be replaced.
So, you mean the O2 wiring diagram for Civic Type R EP3 and Integra DC5 is the same right?
That's why you recommend for test this ECU into another working vehicle.
Posted: Mon Jan 08, 2024 10:11 am
That is correct
Posted: Tue Feb 27, 2024 9:09 pm
by ponsit
VTP is B9.
Should i wire the “ECU 53 SEE SHEET 2“ in the red circle to B9 pin at the ECU then modify the calibration.
Am I correct ?
Posted: Wed Feb 28, 2024 10:08 am
That does not appear to be the wiring diagram for a Honda, as it says Lotus.
Posted: Thu Feb 29, 2024 5:24 am
by ponsit
Spunkster wrote: Wed Feb 28, 2024 10:08 am That does not appear to be the wiring diagram for a Honda, as it says Lotus.
Can you guide me how to wiring
A/C on-off to pin B9 on EP3 ECU ?
Posted: Thu Feb 29, 2024 11:10 am
You need to look at the factory 02-04 RSX service manual and or the ETM.
