v-tec 3000rpm setting durability?
RS800
Post by RS800 »
Hello. I recently received an rsx type s hondata ecu. I installed the k-pro program and uploaded the map that was most similar to my car's tune. k20a2-rsx-310cc-todahdr.kal. The v-tec setting is 3,000 RPM, but isn't that too low? Conservative on the built-in map durability? If the tune is the same, will there be any durability issues? For track driving purposes.
The car is currently doing very well on the streets. There are no warning lights. Below is my vehicle tuning details. Will there be any problems driving on the track with the v-tec 3000rpm setting?
Skunk2 Alpha 74mm Throttle
Honda RBC Intake Manifold
Cai
Fidanza Aluminum Flywheel 8lb
Stainless Race Manifold Long Tube Header 4-2-1
Toda same shape
HKS Hi-Power Exhaust w Silencer
Ngk Heat range 8 plug
lightweight pulley
Mishimoto Racing Thermostat
