Error p2279 k24z3
VIadimirZ
Error p2279 k24z3
Post by VIadimirZ »
Good afternoon. After installing a wastegate on the intake manifold of the TVS1320 compressor k24z3, error p2279 constantly appears. Is it possible to make a window in the menu to disable it? Thank you
VIadimirZ
Re: Error p2279 k24z3
Post by VIadimirZ »
TSX 2012 US АT
Is it venting to atmosphere?
VIadimirZ
Post by VIadimirZ »
Sure
I would upload a photo, but I don’t understand how to do it :)
PS You did it once for our other project disabling p0128
It cannot vent to atmosphere as it will alter the amount of air that the AFM has measured already.
VIadimirZ
Post by VIadimirZ »
The motor operates using MAP. The MAP sensor is located after the wastegate. MAF is only needed for automatic transmission
Our software engineers will put this in the next release for you to try. There is no guaranty it will work.
VIadimirZ
Post by VIadimirZ »
Thank you very much. I'll test it and report back
antisocial
Post by antisocial »
VIadimirZ wrote: Thu Nov 16, 2023 1:26 pm Good afternoon. After installing a wastegate on the intake manifold of the TVS1320 compressor k24z3, error p2279 constantly appears. Is it possible to make a window in the menu to disable it? Thank you
Out of curiosity, was that code present before the wastegate modification?
Is this a MercRacing Supercharger setup?
Reason I ask is that I have one, and plan to install it soon.
VIadimirZ
Post by VIadimirZ »
This is an external Tial MV-S 38 wastegate. It has nothing to do with the compressor itself
The previous version of the engine with the Merc Racing TVS900 compressor had no wastegate at all. The engine was set to a boost of 8,5 in summer and 11,5 in winter (the air temperature is lower - the boost from the compressor becomes higher). The same version of the engine with Merc Racing TVS1320 boost 14,5 in summer and 19 psi in winter, which is a lot. That's why a wastegate was installed
VIadimirZ
Post by VIadimirZ »
Everything works perfectly. Thank you
antisocial
Can we add this feature to the 2011-2014 US Spec MT as well?
It has been put on the list.
