Page 1 of 2
Rev limit at Vtec
Posted: Wed Nov 15, 2023 9:53 pm
by BicBoySam
I installed a turbo kit on my GSR swapped EK hatch and now when VTEC tries to engage I hit a rev limit.
Fuel is rich enough, and timing is accurate,
I have tripple checked all of my grounds
Replaced, plugs and dizzy,
Spark plugs are resistor based
Tested VTEC solenoid with 12v source to verify it clicks
Verified wire continuity between s300 and VTEC solenoid
Oil pressure is above 70 when near VTEC rpm
No CELs
VTEC spool and pressure switch are disabled
Car has no other issues besides this one
Any help would be greatly appreciated
Thank you
Re: Rev limit at Vtec
Posted: Thu Nov 16, 2023 9:38 am
Post pictures of the grounds in your engine bay.
Posted: Thu Nov 16, 2023 1:01 pm
by BicBoySam
As Requested here are my grounds.
Posted: Thu Nov 16, 2023 1:34 pm
I don't see a ground from the chassis to the valve cover stud.
Posted: Thu Nov 16, 2023 1:51 pm
by BicBoySam
Sorry I forgot to include that one, but it is present, I have attached an additional picture of my engine bay where you can see it.
Posted: Thu Nov 16, 2023 2:55 pm
by DaX
The valve cover ground is incorrect. It should go under the acorn nut that holds the valve cover down to the head. Where it is currently attached, it is not providing a ground path, as the valve cover is electrically insulated from the cylinder head.
Posted: Thu Nov 16, 2023 4:12 pm
by BicBoySam
I moved the Ground as suggested and am still having the same issue,
Posted: Thu Nov 16, 2023 4:16 pm
Are you using resistor or non-resistor type spark plugs?
Posted: Thu Nov 16, 2023 4:22 pm
by BicBoySam
Resistor style
Posted: Thu Nov 16, 2023 4:23 pm
by BicBoySam
Posted: Thu Nov 16, 2023 4:39 pm
Post a picture showing the complete inside of the ECU.
Posted: Thu Nov 16, 2023 4:43 pm
by BicBoySam
As Requested
Posted: Thu Nov 16, 2023 5:03 pm
Did VTEC ever work using this ECU?
Posted: Thu Nov 16, 2023 5:06 pm
by BicBoySam
Yes When it was NA it was able to hit VTEC with no issues
Posted: Thu Nov 16, 2023 5:28 pm
According to the datalog it is not hitting a rev limit. Post the calibration that the datalog was made with.
