Rich idle and low load part throttle
Americium
Post by Americium »
I have a 2012 Civic Si with 3” uncatted exhaust and 3” exhaust using the stock airbox with hps intake tube and k&n drop in filter that I am tuning with a MAP calibration. For some reason my car idles at 13 afr and when I’m driving at low load it will also be at around 13 unless I give it some gas and then it will even out at 14.7 again but will do the same thing again if I take my foot off and out it back on unless I abruptly get in the throttle. Is there any way to adjust idle afr? It was also doing this prior to the exhaust and exhaust install but never went away.
Americium
Re: Rich idle and low load part throttle
Post by Americium »
Delete
