Idles very high(3000rpm) tho changing parameters
Posted: Thu Oct 26, 2023 7:50 am
by Akira
<Problem>
Idles very high (3000rpm)
I cannot decrease idle rpm even though changing idle parameters.
I tried decreasing "Idle speed" and "Idle valve duty cycle adjustment"
When ECT is low, it idles around 1200rpm. However, once ETC gets higher, it idles up suddenly to 3000rpm.
- vehicle: NB miata swapped with k24a. The engine is from JDM odyssey absolute.
- serial number: 64860
- version: kpro4
- ECU part number:37820-PPA-A58
- KManager version: 4.5.6.0
- stock miata/ stock engine
- bought kpro4 at KPowerIndustries in this July
Akira Takikawa
Best,
Re: Idles very high(3000rpm) tho changing parameters
Posted: Thu Oct 26, 2023 12:30 pm
by TTR
Most likely the IAC is stuck. Take the IAC apart and clean the vane and housing until it spins freely.
Posted: Thu Oct 26, 2023 4:06 pm
by Akira
Thank you very much for the quick response.
I will try to clean IACV.
