KPRO v4 S/N: 61276 - No Longer Working (Red blinking light)
RoadsterAlex
Post by RoadsterAlex »
Hello, My kPro Stopped working.
I have sent it to the dealer who have told me I need to buy a new ECU and New KPRO as they tried:
- My KPro in a different ECU.. they said car would not start even though mine did; but since the map cannot be changed could be their injectors etc
- Another KPRO in my ECU, Said it didn't work either.
- I tried Uploading, Downloading, Reset KPRO without success
- When I check the Hondata software I have the latest one (4.5.6.0) and no data (gauges) showing up and data logging is flat as there is no data
- I'm Located in the UK, I guess I need to ship this to the US or is there an Official EU/UK Repair Centre?
Video Link: https://youtu.be/QHlj474aF0s?si=U4x0-wOZP6qm1Ws4
As a note, the ecu worked fine, went to dyno and few days later it stopped
K-Swapped MR2 ZZW30
ECU: 37820-PRA-E13
S/N: 61276
Re: KPRO v4 S/N: 61276 - No Longer Working (Red blinking light)
This was sold as an install kit to Type Two. They will have to handle any replacement or installation into a different ECU. You need to determine what in your vehicle caused the damage and correct it so that you do not damage another ECU or K-Pro.
RoadsterAlex
Hi,
They said:
My Kpro doesn’t work in another Ecu
Another Kpro doesn’t work in my Ecu
They also said that pins looked “damp” but that can’t be a reason my Kpro totally stopped working if I’m correct?
Other than that they don’t know what could be wrong.
If both the ECU and K-Pro were damaged, then there is a significant wiring problem either with grounds or somewhere else.
RoadsterAlex
Is this still a replacement or do I need to buy everything new?
You would have to supply a working ECU and pay for the installation charges and replacement cost for the K-Pro. The dealer will have to handle this for you.
