Auto Idle Stop
Posted: Sun Oct 08, 2023 1:24 pm
by thesilverbullet
is there a permanent option to turn off auto idle stop for '23 RDX & ITS? indirect method by changing idle speed?
Re: Auto Idle Stop
Posted: Mon Oct 09, 2023 9:33 am
There is nothing in the software to disable this.
Re: Auto Idle Stop
Posted: Mon Oct 09, 2023 5:59 pm
by thesilverbullet
thank you.
Re: Auto Idle Stop
Posted: Sat May 25, 2024 8:24 pm
by thesilverbullet
Re: Auto Idle Stop
Posted: Sun May 26, 2024 7:25 am
That's for a different vehicle and ECU.
Re: Auto Idle Stop
Posted: Sun May 26, 2024 12:04 pm
by thesilverbullet
thank you for the quick reply. any reason the feature is not an option for USA - rdx, its, ctr? i would purchase flash pro for my rdx just for this option.
a work around is to have an option to select the default dynamic mode as sport or sport +. possible?
Re: Auto Idle Stop
Posted: Tue May 28, 2024 6:30 am
I'm not sure what you are asking. For the FK8, the US vehicle does not have idle stop/start. Only some of the Euro vehicles.
Re: Auto Idle Stop
Posted: Fri May 02, 2025 8:55 pm
by thesilverbullet
Checking in to see if this feature was added.
Thanks for the reply and sorry for the confusion - I’m referring to a USA ‘23 rdx. The idle stop/start feature is a real pain. I would order a flash pro if you added an option to disable the idle stop/start feature.
Re: Auto Idle Stop
Posted: Wed May 14, 2025 5:57 pm
by jeffx
thesilverbullet wrote: Fri May 02, 2025 8:55 pm
I too am hoping it's possible to add it to the RDX FlashPro. I helped my friend flash his 2024 Civic Si and the feature exists for that application to disable idle stop.
Re: Auto Idle Stop
Posted: Mon Sep 15, 2025 5:55 am
by chrisrkooz
You can cancel the auto idle by tapping into the auto-stop pedal switch (there should be a dedicated switch meant only for auto-stop). If you add a bypass to always provide voltage, it will think that you're not on the brake (or clutch). In my car, a 2011 Honda CR-Z, doing this does not cause any long-term issues. Sometimes after about an hour of driving and some other condition I can't figure out, the vehicle shows a 'check IMA' light which goes away after turning the car off. The code goes away but is stored and shows up using an HDS as a auto-stop switch malfunction.
Re: Auto Idle Stop
Posted: Mon Sep 15, 2025 11:31 am
by jeffx
chrisrkooz wrote: Mon Sep 15, 2025 5:55 am
I would prefer to have Hondata just give us the ability to disable it in software (particularly for 2019-2025 RDX)
