Hi guys I’m pretty new to this,
Just asking what ECU should I be looking for for my k24 swapped ek civic. I’ve read so many conflicting opinions, just asking if say a PNF hondata ecu will work with a 02-04 dc5(rsx) engine harness?
Thanks.
What ECU to use
- CalibratEd
- Contact:
Re: What ECU to use
To my knowledge you can use the ECU. The only thing is if you are running a type s transmission you will not be able to use the reverse lock out. Double check if the pins are the same.
https://www.phearable.net/information/t ... grams.html
-Ed
-Ed
Instagram: calibrated.tuning
