2015 si K24z7w k20z3 head base map ?
JoshEK4
Post by JoshEK4 »
hi guys i have a 2015 civic si i did a k20z3 head and pistions car has rdx injectors and rbc intake. what base map should i use. right now i canot start the car only cranks.
CalibratEd
Re: 2015 si K24z7w k20z3 head base map ?
Post by CalibratEd »
JoshEK4 wrote: Fri Sep 22, 2023 2:18 pm hi guys i have a 2015 civic si i did a k20z3 head and pistions car has rdx injectors and rbc intake. what base map should i use. right now i canot start the car only cranks.
Welcome to the forum,
I suggest you find a base calibration with the mods closes to yours and make adjustments to make the car run safe until you get it properly tuned. Make sure you switch the car to run on speed density. Hondata might already have a calibration with RDX injectors. You can use that as a base or find another calibration and you input the injector data yourself.
-Ed
Instagram: calibrated.tuning
