D17 Hondata Cam Gear?
Posted: Wed Sep 13, 2023 7:53 am
by edgar_rz716
kpro v4 sn:63199 on a pnf-ao3 in a d17 civic.
I've been having this problem where ever since i installed the hondata cam gear, the car does start, but shuts off after 5 seconds. First, I thought I set the timing wrong after I changed the cam gear, so I went back and quadruple checked all the timing marks and still the engine shuts off after 5 seconds. So out of curiosity i went back and installed the stock cam gear and it actually ran for longer, but extremely rough as expected. So now i want to know why this could be?
I included logs for both cam gears and the calibration in the ecu.
Re: D17 Hondata Cam Gear?
Posted: Wed Sep 13, 2023 9:03 am
What was the original ECU part number?
Posted: Wed Sep 13, 2023 9:35 am
by edgar_rz716
the numbers on the ecu are 37820-pnf-a03 2091-304559
Posted: Wed Sep 13, 2023 11:25 am
I need the part number that was originally in the vehicle.
Posted: Wed Sep 13, 2023 12:00 pm
by edgar_rz716
my fault it’s 37820-plr-a03 1835-166070. this is the stock ecu part number.
Posted: Wed Sep 13, 2023 3:46 pm
I would recommend that you try the ECU on a known working vehicle such as an RSX or another vehicle that can run the K-Pro and see if it runs as it should. If it does then the problem is either mechanical or wiring related.
Posted: Wed Sep 13, 2023 6:12 pm
by edgar_rz716
okay thanks. is there any known wiring faults that would cause the hondata cam gear to shut off the engine after 5 seconds, but let the stock gear run?
also, what happens if i keep the stock gear on since it seems to work better than the hondata gear?
Posted: Thu Sep 14, 2023 8:57 am
You cannot use the stock gear as the triggers are in the wrong places. The cam timing may not be set correctly. I'm not aware of any specific conditions that might cause this.
