FL5 replacement G25-660
amybydu
Basemap help FL5 Garrett G25-660
Post by amybydu »
My FL5 is replaced by Garrett G25-660, how can I get a Basemap? I am using OEM basemap modification and the car is not driving correctly.
amybydu
Post by amybydu »
Hello, I have an FL5 and I have replaced it with a Gerrit G25-660 turbocharged . I encountered a problem while tuning and used OEM files to make the necessary modifications. May I ask if you need to provide a new MAP to make the necessary changes to my car?
Re: FL5 replacement G25-660
Please elaborate on 'used oem files'. What was the problem? What calibration are you using now?
Normally a turbo swap will run just fine as long as they get the wastegate correct.
amybydu
Post by amybydu »
Check my corrections and datalog
amybydu
Post by amybydu »
I use the Factory settings file to create my calibration,
Now my problem is, WG will start when BP has not reached BP.CMD.
And I think my AFM is incorrect because on my G25-660, shouldn't the 2bar turbo pressure be only 320g/s?
