reflash ajustment
Posted: Mon Aug 28, 2023 7:52 pm
by puzzleo
have taken a datalog of the tune uploaded and have a high knock count for a 20 minute drive of 40 most located on cylinder 3
Re: reflash ajustment
Posted: Tue Sep 12, 2023 2:54 pm
by CalibratEd
Have you reduced timing in areas where knock is present?
-Ed
Posted: Fri Nov 17, 2023 9:06 am
by puzzleo
hey ed this is the tune i have as well thanks
by puzzleo
CalibratEd wrote: Tue Sep 12, 2023 2:54 pm
-Ed
here
Posted: Sat Nov 18, 2023 1:55 pm
by CalibratEd
I adjusted the timing where knock was present.
Create another normal drive log. I want to see if the knock count was reduced.
-Ed
Posted: Sat Nov 18, 2023 9:22 pm
by puzzleo
hey i sent it to ur email as the data log was abnormally large for some reason
Posted: Sun Nov 19, 2023 3:10 pm
by CalibratEd
Per your email I am not sure why the VSA or ABS light may have come on. I do see the knocking significantly dropped so that means we are on the right track.
Create another normal drive log. Keep the log under 15min. If you go higher than that you will have trouble uploading it due to the size.
- Ed
Posted: Mon Nov 20, 2023 1:53 am
by puzzleo
hey ed thankfully the abs and vsa light went away after uploading this new tune,
Posted: Mon Nov 20, 2023 8:14 am
by CalibratEd
The knock count is down to 2. I adjusted the timing again to eliminate the remaining knock. You should be good to normal drive the car.
- Ed
