K pro won't turn on
Brucecb1430
K pro won't turn on
Post by Brucecb1430 »
I have a ek k24 k swap. I had no issues the car was running fine, then it sat for 2 weeks now ecu turns on but kpro does not. I can't connect to it with my laptop or anything. I have the hybrid racing ground kit installed, injector ground is ground to the side of the head since my valve cover is powder coated. Any advice? Fuses are good, main relay is good. Car will start but runs poorly. I attached pictures of my kpro board and ecu.
Re: K pro won't turn on
Dcuevas913
Post by Dcuevas913 »
I have same problem any answers?
Dcuevas913
I am running latest version available
What is the actual version of software from Help, About.
Dcuevas913
Version 4.5.6.0
Dcuevas913
Car starts everytime just no lights on kpro board and no signal to laptop when connected
It looks like that K-Pro was sold as an install kit to XPerformance. You will need to have them check it out as it could be an installation issue.
Dcuevas913
Would this be the same thing I would need to do for mines.
Dcuevas913
Dcuevas913
63173 is on kpro board
What vehicle is this in?
What has changed since it last worked?
Dcuevas913
This is in 99 civic coupe
K24 with element 5 speed
Nothing has changed I just finished swap. Had been working before last thing I did with the car was depinning and reppinning vss plug. Car still starts no lights com on kpro board
Dcuevas913
Won’t even come up when connecting to laptop which it preciously did
I would check what you have recently changed as it sounds like something is not wired correctly.
