p1166 2002 crv MT rbb3 kpro v3 aem 300
notsonerdy
Post by notsonerdy »
car setup:
2002 crv MT, rbb3, kpro v3, aem 300
after I swapped in the rbb3 / kpro v3 it threw me p1166, so it was suggested to get an aem 300 AF gauge
I wired the signal to analog 0 and changed the "conversion" in the analog tab to AEM -0300, in the wide band tab in the settings ( use analog 0), and disabled secondary on the closed loop tab as well as unchecking the immobilizer and secondary 02 in the 'misc' tab
I am still getting code p1166 and the dashboard on the laptop isn't reading any numbers while the gauge itself is reading a steady 14.7 at idle ( fluctuates when throttle is engaged)
ive read on here that a p1166 code means the ecu is bad, is this true
Re: p1166 2002 crv MT rbb3 kpro v3 aem 300
Are you trying to run closed loop from an aftermarket wideband?
notsonerdy
im trying to just make it work
I plan on this being a stock swap, nothing special
You have a V3 K-Pro and it cannot use an external wideband for closed loop. That can only be done with the v4 K-Pro.
notsonerdy
I dont have that function requested - under that tab I have disabled ( open loop)
my issue is with the code... id happily take out the AEM o2 sensor and go back to stock if the p1166 would go away
this is my issue, any advice on how to remedy it would be appreciated
rbb3crv
Post by rbb3crv »
Post your calibration
rbb3crv
Post by rbb3crv »
how do i get there
rbb3crv
Post by rbb3crv »
crv a2 map 1.kal
rbb3crv
Post by rbb3crv »
is this what you are looking for
It sounds like either the factory wideband or the wiring for it has been damaged when installing other parts. I would follow the factory service manual for troubleshooting that error code.
rbb3crv
Post by rbb3crv »
it worked fine before but it was damaged while the motor swap happened?
that doesnt make sense... im inclined to believe its a setting im missing here
i have 2 brand new 02 i'll fire in, lets see how they go
rbb3crv
Post by rbb3crv »
Po134
Bank 1 no activity
rbb3crv
Post by rbb3crv »
I put the original back in and it idled with out codes -texted for 5min
Still laptop program still doesn't have any a/f readings
Post the current calibration and a datalog showing what it is doing with the stock O2.
