Hello,
I need some help in getting my swap up and running properly. I swapped in a K24a2 Rbb1 about 3 months ago but haven't been able to drive cause its not tuned at all. I did start and drive it just once around the block to make sure things were done correctly. The car doesn't rev correctly and hangs allot. I'm sure it is from running the stock ecu its not knocking or anything no CELS. I'm hoping someone can help get me in the right direction on a Tune. Completely Stock RBB 1 , with stock 25 deg vtc, Civic Si Intake manifold RBB I believe, stock Civic Si injectors and that is it. Stock header and exhaust from 06 Si. it does also have a intake but I kind of just hacked a old AEM cold Air after the MaF and put a filter on it. if that will be an issues right off the bat I can get something more legit. Just trying to get it running safely before I continue to build it. Thanks for any info, excited to get her running and use this Flashpro
Looking for help with Etune for k24 swap
Re: Looking for help with Etune for k24 swap
I'm guessing the intake you made is your problem. I know that when I went to the Hybrid Racing CAI, you have to make changes on the hondata. Try hooking up something with the stock intake just past the sensor, with a filter and see if that helps. Best is find a dyno and get it fully tuned right or at minimum, get an online tuner.
08 civic si proline springs koni orange Hondata hybrid racing CAI with larger throttle body and peeling and faded Blue paint
