K24a2 with k20z4 head
MURPHITOJONES69
Post by MURPHITOJONES69 »
I'm having idle surging from 1.3k to 2.3k. Need assistance.
CalibratEd
Re: K24a2 with k20z4 head
Post by CalibratEd »
MURPHITOJONES69 wrote: Sat Jul 22, 2023 12:56 am I'm having idle surging from 1.3k to 2.3k. Need assistance.
Have you checked for vacuum leaks?
-Ed
Instagram: calibrated.tuning
MURPHITOJONES69
Yes I've checked for vacuum leaks, no vacuum leaks
CalibratEd
Post the calibration file and a datalog. I can take a look at it.
-Ed
MURPHITOJONES69
I'll post it tomorrow morning. Thank you
MURPHITOJONES69
I was able to perform the task
CalibratEd
Double check the IACV. It is throwing an error. It might not be connected and needs to be blocked off or it may have gone bad.
This can cause erratic idling.
-Ed
MURPHITOJONES69
I will check when I get home buy I barely put a new one in. Will the code stay on until I clear it? I'm new to hondata 🤣
CalibratEd
You should be able to clear the DTC with Kpro.
-Ed
MURPHITOJONES69
I cleared the codes. Is 12.6% too much for tps minimum reading?
CalibratEd
The TPS should read 0%. Did you calibrate the TPS?
-Ed
MURPHITOJONES69
Yes. Mine reads 12.6 percent on the throttle calibration section after the reading
CalibratEd
That’s fine as long as the throttle body is fully opening.
-Ed
MURPHITOJONES69
Do you think a tune will fix it?
CalibratEd
A tune will fix what?
-Ed
