Can Flashpro now disable traction control?
CsxtypeR
Post by CsxtypeR »
Hi guys I have a 07 CSX type S I ended up swapping a supercharged drivetrain and tune from a 06 that came without traction control. I swapped everything including the cluster and I am now unable to turn traction control off.
googling shows me posts from 2012 indicating that turning VSA off in the flash pro just disables the light and doesn't actually turn the traction control off. So currently my car traction control does kick on whenever there is wheel spin. however since the cluster doesn't have the trac light it doesnt flash, and my VSA Off button no longer functions.
wondering if Flashpro now can disable traction control in the calibration settings?
Re: Can Flashpro now disable traction control?
The TC and VSA is controlled from the ABS module. If you disable the VSA in the ECU then the ABS will start to do odd things if it does not hear from the ECU. The option to disable VSA only exists for the 06 Si which does not have it.
