Recently bought an S300 V1 and I'm running into an issue where my car stalls at certain RPMs in different gears.
*NOTE* Boost by gear is not on nor do I have any sort of limiters set up. Just using a stock b20 base to work off of.
For Example:
1st Gear @ half/full throttle stalls the engine at 5k RPM
2nd Gear @ half/full throttle stalls the engine at 4k RPM
3rd Gear @ half/full throttle stalls the engine at 3k RPM
4th Gear @ half/full throttle stalls the engine at 2.5k RPM
5th Gear @ half/full throttle stalls the engine at 2k RPM
Now that being said ^^ if I only press the pedal about 5% on the TPS it will gradually go past any RPM I want and it will finally get into boost.
This is just a basemap as well, nothing special. I'm new to using Hondata, but is there something I may be missing?
Fuel & Ignition Cutting on throttle
Re: Fuel & Ignition Cutting on throttle
**FIXED**
For anyone that may have the same problem, you need to manually adjust your TPS settings.
In SManager:
Parameters>TPS>Scale TPS
Throttle Closed - Click Read on Minimum Reading %
WOT (Wide Open Throttle) - Click Read on Maximum Reading %
That should set your TPS. Hope this helps someone.
In SManager:
