Acuity intake basemap
Gunish
Post by Gunish »
Hey, can anyone help me with a base map tune just for an acuity CAI and a catback exhaust. I’m waiting to get all of my bolt ons before I put my car on the dyno, so i’m just looking for a map that I could use to daily drive my car until then.
CalibratEd
Re: Acuity intake basemap
Post by CalibratEd »
Use a map with the closes mods to yours and switch it into speed density.
I can review the logs.
-Ed
Instagram: calibrated.tuning
Gunish
Post by Gunish »
Thanks for the reply. I’ll post a log in an hour but i’m running the hondata reflash right now with the crackle/ pop tweaks in the ignition graphs. I’m not sure how to change the ratios for fuel and everything so i’ll post the map and the log.
CalibratEd
Remove all the crackle modifications until it’s dialed in.
-Ed
Gunish
Post by Gunish »
Sorry for the delay. I've attached the map that I'm running and 2 data logs.
CalibratEd
Remove the crackle modification and redatalog the car.
-Ed
Gunish
Post by Gunish »
So, I'm using the same map now without the pop/crackles, and my EMS light came on for a while, and it went away on its own. I've attached the datalog before it came on and the map.
CalibratEd
Down low the car needs a bit of fuel added. Up top the car is running very lean. It is hitting 14AFR at WOT and you can damage something driving the car that hard. When you change the stock intake it is best to switch to a speed density tune. What other bolt ons do you have left to install?
-Ed
Gunish
Post by Gunish »
Yea, I could feel it running different. I’m going to be installing a full race in a couple of weeks but for now just the intake.
Gunish
Post by Gunish »
Here's the map
Gunish
Post by Gunish »
The datalog
CalibratEd
Gunish,
I made a few minor fuel adjustments. Load the new file and create a datalog.
-Ed
Gunish
Post by Gunish »
I've attached 2 datalogs. 1 is highway drive and 1 of them is city
CalibratEd
Gunish,
Cleaned up a bit more of the fuel. It is running lean.
Load the new file and create another datalog.
-Ed
Gunish
Post by Gunish »
The throttle feels a little unusual, I'm not sure why. It feels like there's more rev hang than normal and while rolling the rpms just drop for a quick second sometimes.
