Ignition table not able to edit
2007-2008 Fit
Tonyb16a
Post by Tonyb16a »
In my ignition low/high theyre are some boxes i cannot edit the values, theyre stuck at -10.00. But in the improved throttle response tune theyre lesser than -10.00. The top right corner values.
Re: Ignition table not able to edit
Post your calibration and a screenshot showing what you are referring to.
Tonyb16a
Post by Tonyb16a »
Its the basemap 270cc accord injectors
Post the actual calibration.
Tonyb16a
Post by Tonyb16a »
What you are saying is that you cannot set the ignition to less than -10 degrees. We'll change it for the next release.
sleepingAwake
Post by sleepingAwake »
Hondata wrote: Fri Jul 07, 2023 9:01 am What you are saying is that you cannot set the ignition to less than -10 degrees. We'll change it for the next release.
Ya know I noticed that as well. I had changed some of those areas and I wasnt able to set it back to -10. I think -2 was the lowest I could go.
If I accidently changed it from -10 to a higher value and wanted -10 back the only way to do it was to revert to an earlier save or an untouched version of that tune.
I dont really have a reason to change those areas but it was an interesting "bug" I noticed.
