Replaced 2 injectors and tune is totally out of whack.
adampwoolwich
Post by adampwoolwich »
Hi,
First all I am a tuning noob. I am decent at working on the mechanical side of my car but as for wiring and tuning, it's almost a foreign language.
I have a k20a2 in a 2003 Civic sir. I have a prb ecu and trans with exedy stage 1 clutch, lightweight flywheel (around 9-10lbs) mfactory helical diff, RBC ported to 72mm (TB side only) skunk2 thermal I'm gasket, 72mm ktuned tb, kpro v4, Aem 3.5" Cai, skunk2 alpha 421 rh (2.5") running to a yonaka 2.5 exhaust that had slight fabrication to clear my progress rear sway bar. I also have Aem uego x wideband and guage, baffled sump and all the geometry and suspension done. .
All of these parts were installed in the last 6 months and I have only done about 3500 kms since the build. I also have brand new timing components (OEM) and oil pump chain. The car was on a street tune and was running fairly well, especially at the track which is where this car spends 90% of it's time. I began to experience rev hang, high idle and stalling issues, All lead me to beleive either iacv, TPS or injector. I bought a new fuel rail and the pintle can and oring on cylinder 1 got stuck in the RBC. That explained all my symptoms.
A friend of mine gave me a set of four injectors and told me he believed they were form a k20a2. Anyway I fished out the cap and oring (with a Dyson because I dropped it into the manifold lol) everything came out a ok. So I pulled the bad injector out and installed the best looking 1 from my friends set. I only replaced cylinder 1 as all 3 other injectors looked healthy and put new o rings on. The injector turned out to be a a3 (270cc) against my other 3 OEM prb 310cc's.
So I reached out to another friend who I met today and he gave me 2 k20Z3 injectors. So I pulled the the worst a2 injector as well as another one that looked ok, but no where near as. Clean as the newer z3 injectors. I staggered them 1 prb then 1 z3 and repeated in the last 2.
I started the car and I immediately noticed it running better. However my aem wideband was reading 16-18/3-7 afrs. I figured with two 310ccs from the z3 would be almost identical to the a2s. So I plugged in and downloaded my street tuned map done by the shop that did some of the above mentioned work. I noticed the z3 injectors had a slight round edge on the metal caps, but they were the same in size other than that.
Long story short kpro kmanager was reading 14.6/14 7 at idle where as my aem wideband was reading the higher afrs mentioned above. I hope this isn't a stupid question but wouldn't all injectors with a 310cc rating behave the same based on my previous tune. This was not the case
A. Which reading do I beleive is more accurate? Kpro v4 or Aem wideband
B. Does the slightly different shaped metal cap make a big difference with spray pattern, or atomization make that big of a change 3D between my afr's?
C. Is there anything I can calibrate within the app, say a setting about the I injectors without having to try tune the variance out?
D. Should I just buy a matching set of OEM injectors 310ccs as I was topping out at 82% duty on the prb 310s before the one broke.
E. Should I leave these injectors in and just get a re-tune?
F. Or should I just get rdx 440s o a set of deutchworks (similar cc I think 350 or 55p with a higher flow rate, to future proof the car and get a re-tune.
Sorry for the rant. I just wanted to get some advice on what direction is most likely to make my car run well again. I plan on leaving the car.na as it's just my reliable track toy.
Sorry there is no data logs but I only got the car running again tonight.
Thanks so much in advance!!
Re: Replaced 2 injectors and tune is totally out of whack.
You need to get 4 matching injectors that have been flow tested and have nearly identicle flow rates between them. Using mismatched injectors is a recipe for disaster.
adampwoolwich
Ok thanks for the quick response. Ordering now!
adampwoolwich
What Injectors would you guys recommend. NA FBO (72mmtb, 3,5 inch injen cai, skunk 2 alpha rh, 2,5 inch exhaust all the way back) possible Cam and valvetrain upgrades. Rdx 410cc, dw 550s, bosch 550s, grams 550s, injector clinic, Id1050s seems overkill, RC so many brands. kpro v4. Im so confused they all seem much of a muchness? im worried if i go over 550cc idle issues may occur. Any input appreciated. Track car 80%, street 20%. i have another DD. Thanks
The brand you choose is up to you and long term goals. Just make sure that the injectors you use come from a reputable source and the dead times are set correctly before tuning with them.
