Flashpro not available connect
Posted: Thu Jun 08, 2023 8:19 am
by ctk0209
Excuse me, My Flash Pro has encountered a problem that the continuous loop download (Updating Flashpro firmware) cannot be interrupted. So i can't connect can not use .there is a solution ?
My flashpro is registered as well. Please let me know.
Flash Pro Manager:version V4.1.1.0
thank you
Re: Flashpro not available connect
Posted: Thu Jun 08, 2023 9:42 am
Is the FlashPro plugged into the vehicle?
Posted: Thu Jun 08, 2023 10:54 am
by ctk0209
Yes, plugged into the vehicle, but it's the same without the vehicle connected, and the same with the USB only
Thank you
Posted: Thu Jun 08, 2023 11:47 am
What is the FlashPro serial number?
Posted: Thu Jun 08, 2023 4:36 pm
by ctk0209
Flashpro:(FP-SI-INT-25188)
Posted: Thu Jun 08, 2023 5:03 pm
After it fails to update, with everything plugged in and the ignition in the on position, go to the Help menu and click on “send feedback”. Include a detailed description of the issue.
Posted: Thu Jun 08, 2023 5:23 pm
by ctk0209
ok i'll try that but i plugged everything in and the ignition in the on position ! would happen (continuous loop download (updating flashpro firmware) . Or use the USB Driver alone for connection?
Thank you
Posted: Fri Jun 09, 2023 9:20 am
Just plug in the USB.
