Fl5 anti lag
Fl5 anti lag
Trying to setup anti lag for my fl5 and can’t get it to activate. Was following procedure for the fk8 settings and I get nothing. Set launch control to 3500, speed 1mph, enable full throttle shift, enable anti lag in calibrations, then went into mods and check anti-lag, full throttle part throttle shift, also check disable rev hang. Not sure if it’s different from fk8. Please help. Thanks
Re: Fl5 anti lag
So basicaly you want to blow your engine. You should avoid antilag if you don't have a built and stronger engine.
FK8_Hoonigan
- Contact:
Re: Fl5 anti lag
DittoRares wrote: Wed Jun 07, 2023 11:47 pm So basicaly you want to blow your engine. You should avoid antilag if you don't have a built and stronger engine.
GARIX Tuning
2021 R-39464
https://dot.cards/garix
2021 R-39464
