0x00 Step 13 on FK8
razgriz2010
0x00 Step 13 on FK8
Post by razgriz2010 »
hi there!
i have been modding my CTR Pre-FL and as a finishing touch, i got my hands on a hondata flashpro to fine tune the car based on the hardware that i've installed.
i've successfully jailedbroken the car, and verified by the flashpro manager software. however, when uploading a base tune into the ECU, i get the following error barely a minute into the uploading process. (the dashboard going into christmas lights and shortly after the error pops up). Error attached into this post.
some details:
Car: 2018/2019 FK8 (according to hondata mine's a Mexico ECU?)
Hondata: 2017+ Civic Type R International
Flashpro Manager Version: 4.1.1.0 (i had the same error on 4.0.7.0 too, and i updated to see if it would resolve the issue)
Error: Code 0x00 Step 13 Address 0x000000
Jailbroken: Yes
for some reason when i select a UK/Asia/Japan model, it throws an error and tells me to choose Mexico.
Do let me know if you need any other information.
thank you for your help in advance!
Re: 0x00 Step 13 on FK8
What is your ECU part number?
razgriz2010
Hi there!
I can’t access the label of the ECU since it’s blocked by the intake. I used hondata to get the same (attached)
razgriz2010
Hi there. I also tried flashing with the “2017-2018 Americas” calibration. Doesn’t work either. Same error.
The ECU has been reprogrammed in some way prior to using with the FlashPro and appears to have been programmed improperly. We have replied to the feedback sent from the ECU.
razgriz2010
That’s sad to know. Will follow up with the updates aft the feedback instructions.
