Cluster gauges not working with new basemap
Tyjef
Post by Tyjef »
2000 civic Si
D15b swapped
Stock ecu & basemap
Purchased used s300 v1
Uploaded basemap for d15b on s300 using Smanager
Car turns over with s300 plugged in but gauges on the cluster don't work
The car also has an Sir Cluster not the stock cluster
Noob here so patience is very much appreciated
Anybody know what may be causing this issue?
Re: Cluster gauges not working with new basemap
The cluster should not have anything to do with the basemap or the ECU being used.
Tyjef
Post by Tyjef »
Spunkster wrote: Tue Jun 06, 2023 4:52 pm The cluster should not have anything to do with the basemap or the ECU being used.
The stock ecu works fine its only not working when i plug in the s300, could it be an issue with the conversion harness or the s300 itself?
Which gauges specifically are not working?
