Vtec wows
Posted: Sun May 28, 2023 2:55 am
VTEC wows update.
Stripped back the wiring. Car harness has two small white plugs (Minitec harness).
I've set the hondata s300 VSS to zero and VTEC should rely on tacho to engage VTEC.
There are Two VSS connections on the small white plugs. Pins D & E respectively.
On Hondata SManager I've added VSS to the display screen. No VSS picked up!?
Thinking about it, the VSS will give a pulse to the speedo. The OEM speedo will calibrate to a true speed and send out a revised pulse back to the ECU.
Right?
So if my aftermarket speedo doesn't do that and I jump the cables it won't be a true speed but at least it would give it a speed.
Right?
Right?
Right?
