KManager issues between laptops
Juncura1
Post by Juncura1 »
Hello,
I have switched to a new tuning laptop and when using KManager for my AP1 I noticed that the Map display is using ("/psi) no matter what I change the pressure units to in "Settings" and the AF display is also not reading from my wideband which I have setup in Parameters>Analog inputs.
The old laptop is working without issue so I feel like I'm missing something... it's been a while since I set it up.
Both laptops are running version 4.5.5.0 and I've attached a calibration file.
Re: KManager issues between laptops
Where exactly is it still showing "/psi?
Have you double clicked the MAP sensor in the sensor list and changed it there?
Juncura1
Post by Juncura1 »
Changing it in the sensor list is exactly what I was missing. Thank you for the help.
Any ideas of why I'm not getting readings from my wideband?
"Display" tab > A/F:1
What wideband are you using?
Juncura1
Post by Juncura1 »
I believe it is a Bosch... it's been a few years. I have it setup under "Parameters" > "Analog inputs" > "Analog 0" of my calibration. It's working fine on my old laptop and I can view the A/F in real time. When viewing the A/F in "Display" on the new laptop it stays at 0. I feel like I'm missing something simple, but I can't figure it out.
Juncura1
Post by Juncura1 »
I forgot to mention that I also have the "Wideband Input" under settings to use "Analog Input 0"
Everything seems to be configured the same as my old laptop.
Juncura1
Post by Juncura1 »
I updated to the new Beta version and it's now working.
