JDM K24A (RBB), LOG (for now) with 44mm WG, GTX3582R
Posted: Tue Apr 25, 2023 5:11 am
by RoadsterAlex
Hi all,
Anyone has a base cal for just 5Psi WG pressure on:
JDM k24a RBB, 7700 rpm rev limit at the moment (stock)
Log manifold but with 45mm wastegate
45mm wastegate (GFB EX44) with 5psi spring
Gtx3582R
AN8 return fuel system with 450lph pump
AEM X-series on AN0
UK 97 pump gas (US beteeen 91-93)
Haven’t bought injectors yet but thinking of ID1050x? They are stock 310cc now.
I’ll upgrade to sidewinder later.
Re: JDM K24A (RBB), LOG (for now) with 44mm WG, GTX3582R
Posted: Tue Apr 25, 2023 2:36 pm
by CalibratEd
Alex,
When do you plan on getting your injectors? What map sensor are you running? I would not try to wide open throttle the car until you have the proper injectors.
Do you need something to drive it part throttle?
-Ed
Posted: Wed May 03, 2023 12:27 pm
by RoadsterAlex
Hi ed,
Injectors next week
Hondata 4 bar map sensor
I won’t be driving on stock injectors or stock map sensor :)
Posted: Wed May 03, 2023 12:39 pm
by CalibratEd
RoadsterAlex wrote: Wed May 03, 2023 12:27 pm
Hi ed,
Injectors next week
Sounds good.
What is your plan? Do you plan to dyno tune the car? Do you need something to get you to your tuner?
-Ed
Posted: Thu May 04, 2023 5:42 am
by RoadsterAlex
Something I could drive around (not race around) untill I can get it tuned on the dyno.
They have a long waiting list unfortunately
I don’t use the car a lot but sometimes I do like city/motorway driving
Posted: Thu May 04, 2023 6:05 am
by CalibratEd
RoadsterAlex wrote: Thu May 04, 2023 5:42 am
Sounds good. Reach out when you have everything installed.
-Ed
