New K24A Swap No Spark
caden.0313
Post by caden.0313 »
Hello, this is my first post here after spending a lot of time going through the forum to try and get my motor started.
I have a 2005 S2000 with a K24A turbo swap that I recently completed, and am now trying to get started with my new KPRO v4. I am using an aftermarket RSX 02-04 harness. So far through altering the base map of the stock K24A2 calibration I've managed to get injectors to work, MAP sensor (recently replaced), crank sensor (displays RPMs while cranking), and TPS readings.
Despite going from getting no fuel or spark to fixing grounds and having injectors firing, I still have not been able to have spark. I have 3 separate sets of coilpacks, ranging from 995ohms to 1200ohms, none of which cause my new spark plugs to work, as well as nothing coming from spark tester. I replaced the CPS with a new genuine honda one, and verified that the signal, ground, and power pins on the connector are displaying proper readings for both sensors, as is the same for the coil pack connectors.
Any and all help would be greatly appreciated!
-Caden
Re: New K24A Swap No Spark
I would recommend that you try the ECU on a known working vehicle and make sure you have the immobilizer disabled.
Pro60modman
Post by Pro60modman »
Check voltage at the coils. If you're only getting 10v's with the key on switch pins 7 and 20 on the C101 connector and retest.
caden.0313
Pro60modman wrote: Mon Apr 17, 2023 7:34 am Check voltage at the coils. If you're only getting 10v's with the key on switch pins 7 and 20 on the C101 connector and retest.
Checked voltage at coil connectors, getting 11.5V on battery reference pin, 6Ohm resistance at ground pin, and when cranking ~4.5V fluctuating at signal pin. For the C101 connector pins, should the ones being switched be on the light blue s2000 C101 side or the grey RSX C101 harness side?
caden.0313
Update: Pro60modman you are my fucking HERO
Switched out pin 7 and pin 20 on the grey rsx engine harness C101 connector and the motor fired right up
kswap1234
Post by kswap1234 »
When you say you Switch out the 7 and the 20,you literally switch the 2 wire 1 place to another right? Because i have the same issue
EnzoGorlami
Post by EnzoGorlami »
Hey boss I just wanted to message you about your no spark situation. now I do not have an s2k but I do have a k24a and this same issue, I am running a prb-a06 v4 and i have power and reference and ohm just like you. literally dealing with the same exact issue, however i have an em2/es1 chassis and im about to swap these same pins as im thinking im not wired correctly on the chassis side going into the ecu. i cant find this write up or situation within the es1 k swap write ups, but im feeling on just trying what you did. lemme know what ya think.
