Haltech Pressure Temp Analog input
Posted: Fri Apr 14, 2023 11:40 am
by l337h4l
I have a Pressure Temp in 1 sensor from Haltech.
If anyone is interested it is a Bosch Sensor from 2016-2021 Mazda CX-9 But you have to buy it from Haltech to get the pigtail
Anyhow, as seen in the attached picture the graph value supplied by Haltech is not 1:1 The Values in custom inputs only offer a Start and End point resulting in a linear straight line.
I am running a AEM CD-7 dash If I just set it up the Kpro to voltage and pull the Analog input over as volts can I just convert it there over the CAN?
Lastly for a temp input you need to bring the signal to VCC power via resistor.
Will this effect the pressure sensor using the same power supplied pin?
Thanks in advance
Re: Haltech Pressure Temp Analog input
Posted: Fri Apr 14, 2023 11:50 am
I do not think this will work as you want. You will be much better off using the recommended sensors with part numbers in the help file.
Posted: Fri Apr 14, 2023 12:39 pm
by l337h4l
Spunkster wrote: Fri Apr 14, 2023 11:50 am I do not think this will work as you want. You will be much better off using the recommended sensors with part numbers in the help file.
The AEM CD-7 pulls the analog channels over CAN. I already use the AEM Wideband which was easy. I also have custom surge tank sensors wired in for full and empty which are 0-1v in the Analog inputs. As long as I get a voltage reading into the Analog input the CD-7 will convert the the signal using its function calculation for accurate readings.
But for the custom input voltage fields should I go 0-5?
Also additional question on the wiring sharing power with that pull up resistor would it effect the other sensor?
Posted: Fri Apr 14, 2023 3:51 pm
Are you referring to settings for the AEM?
Posted: Sat Apr 15, 2023 8:38 am
by l337h4l
Spunkster wrote: Fri Apr 14, 2023 3:51 pm Are you referring to settings for the AEM?
I’m referring to Kpro input settings. My other non supported sensors are just raw voltage. If I pull that I know the AEM can convert it. I don’t think I need the pull up resistor is that just required for the recommended sensors?
Posted: Mon Apr 17, 2023 8:59 am
Have you tried setting it to voltage instead of AF in the analog settings?
