2007 honda civic 3.5 CAI
Posted: Tue Apr 11, 2023 8:11 am
by Mat.fg2
Hey guys new here, I have a 2007 civic si and just got a 3.5 inch intake everything else stock (expect no cat) could anyone help me out with getting a little base tune for It without my car running like trash, also couldn’t see any map tunes in the base tunes on hondata.
Any help is much appreciated.
Re: 2007 honda civic 3.5 CAI
Posted: Thu Apr 13, 2023 7:12 pm
by CalibratEd
I suggest you start with a stock base and adjust accordingly. I can review the logs.
-Ed
Posted: Fri Apr 14, 2023 7:40 am
by Mat.fg2
Thanks for the response!
Okay this is the tune I have on at the moment I found on a link on here sense the intake is hybrid racing except the silicone hose, seems to be running pretty good.
And So I took a datalog last night I’ll attach it on here when I get home but I have a « Knock sensor 1 » out so it wouldn’t show my kocks right?
Should I wait till I get the knock sensor next week or could you still be able to help me out with the datalog?
Again all help is appreciated thank you
Posted: Fri Apr 14, 2023 3:48 pm
by CalibratEd
Mat,
I suggest you fix your knock sensor issue before I review any logs.
-Ed
Posted: Fri Apr 14, 2023 4:47 pm
by Mat.fg2
Will get on that thanks lmao
Posted: Sun Apr 16, 2023 1:13 pm
by Mat.fg2
alright got the knock sensor issue fixed
got some improvement to do on the tune for sure but idk much so to me seems fine
got a 20 min datalog 2 WOT
idk if it matters but my car is pretty low and these roads are shit so idk if that messes with it
let me know what you think appreciate the help.
Posted: Mon Apr 17, 2023 9:01 am
by CalibratEd
Mat.fg2 wrote: Sun Apr 16, 2023 1:13 pm alright got the knock sensor issue fixed
The car is running well on the Vtec side and there is only 1 count of knock.
The car is running lean on the non vtec side on the lower vacuum section (columns8,9,10 )
-Ed
Posted: Mon Apr 17, 2023 3:03 pm
by Mat.fg2
Great! Thanks for the feedback Ed
So should I just adjust there a bit and be all good till I put new parts in?
Also in calibrations what would that be under?
Everything else looks good?
Posted: Mon Apr 17, 2023 7:33 pm
by CalibratEd
Mat.fg2 wrote: Mon Apr 17, 2023 3:03 pm Great! Thanks for the feedback Ed
Yes adjust those areas so you aren’t running so lean. You would make the edits on the fuel tables. There are a few tables that are used. Look at the Lambda delta table. It shows you how far off the afr is and where the changes need to be made.
All else seems to be running safe.
-Ed
Posted: Tue Apr 18, 2023 5:54 am
by Mat.fg2
Perfect thanks for all the help man have a good one
Posted: Tue Apr 18, 2023 3:50 pm
by CalibratEd
Mat.fg2 wrote: Tue Apr 18, 2023 5:54 am Perfect thanks for all the help man have a good one
No problem. I'm glad I could help. Reach out if you have anymore questions or if you're interested in a custom tune.
-Ed
