PLX to Kpro V4
pumadunk
PLX to Kpro V4
Post by pumadunk »
Hi, I have a PLX AFR gauge and module trying to hook up to a Kpro V4. I did all the wiring as instructed, grey from PLX to Kpro v4 analog 0 red wire. PLX grounded to same grounding point as the ecu. Right now, the ecu recognizes there is a widened connection, but the AFR reading on Kpro V4 is locked at 10.0 at idle, not following the PLX reading at all. Is this a wiring problem from PLX or is it a ground issue?
Re: PLX to Kpro V4
Where exactly are you getting power and ground for the wideband?
pumadunk
Re: PLX to Kpro V4
Post by pumadunk »
I’m getting power from ignition and grounding is to the location where the ecu grounds which is the engine. The gauge reads fine but not reading in Kpro
Re: PLX to Kpro V4
Have you checked the voltage of the output with a multimeter?
pumadunk
Re: PLX to Kpro V4
Post by pumadunk »
Not yet. But if the output wire to Kpro has power, then what other issues could it be?
Re: PLX to Kpro V4
You need to first see if the voltage matches what the PLX is reading on the display.
pumadunk
Re: PLX to Kpro V4
Post by pumadunk »
You mean check the Hondata display for voltage ?
Re: PLX to Kpro V4
No, you need to measure the output voltage of the PLX to see if it matches what it is showing.
pumadunk
Re: PLX to Kpro V4
Post by pumadunk »
I see, so you are referring to the equation (AFR-10)/2 right to get the voltage, and vice versa for the AFR. So if that matches, then what?
Re: PLX to Kpro V4
If it does not coincide with the reading then you need to contact PLX about what the problem might be with the wideband controller.
